[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:55 EDT 2006
Hello helena,
ANALYSIS
lib/rst/interp_float/point2d.c functions
IL_check_at_points_2d (Begins at: 35 Ends at: 195)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      38 |     * |         |
LOC:          |     161 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
