[GRASS-QA] SOCCER LAB GRASS QA: 3 clones ( Dscreen.c list.c get_row.c get_row.c put_row.c put_row.c vect.c areas.c draw.c position.c get_row.c pad.c main.c main.c command.c parser.c GS2.c gethead.c anim_support.c draw.c position.c site_attr_commands.c site_highlight_commands.c togl_flythrough.c parser.c raster.c line.c main.c ) 0 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:56 EDT 2006
Hello soeren,
ANALYSIS
raster3d/r3.out.vtk/main.c functions
CreateInputMapsStruct (Begins at: 55 Ends at: 80)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
OpenInputMap (Begins at: 85 Ends at: 100)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
CheckInputMaps (Begins at: 106 Ends at: 181)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      76 |       |      OK |
metrics are OK
OpenWriteRGBMaps (Begins at: 187 Ends at: 265)
Complexity:   |      19 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      79 |       |      OK |
metrics are OK
OpenWriteVectorMaps (Begins at: 270 Ends at: 348)
LOC:          |      79 |       |      OK |
metrics are OK
main (Begins at: 354 Ends at: 540)
Complexity:   |      23 |     * |         |
CalledNBR:    |      65 |    ** | Warning |
LOC:          |     187 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file has 3 potentially cloned functions:
  OpenInputMap  OpenWriteVectorMaps  OpenWriteRGBMaps
In raster3d/r3.out.vtk/main.c clones of  OpenWriteVectorMaps are:
	raster3d/r3.out.vtk/main.c  OpenWriteRGBMaps
In raster3d/r3.out.vtk/main.c clones of  OpenWriteRGBMaps are:
	raster3d/r3.out.vtk/main.c  OpenWriteVectorMaps
In raster3d/r3.out.vtk/main.c clones of  OpenInputMap are:
	raster/r.to.rast3/main.c  OpenInputMap
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
