[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( Dscreen.c list.c get_row.c get_row.c put_row.c put_row.c vect.c areas.c draw.c position.c get_row.c pad.c main.c main.c ) 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:52 EDT 2006
Hello glynn,
ANALYSIS
display/drivers/XDRIVER/main.c functions
main (Begins at: 5 Ends at: 49)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  main
In display/drivers/XDRIVER/main.c clones of  main are:
	display/drivers/PNG/main.c  main
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
