[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:52 EDT 2006
Hello glynn,
ANALYSIS
imagery/i.fft/fftmain.c functions
main (Begins at: 29 Ends at: 268)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      92 |   *** | MONSTER |
LOC:          |     240 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
