[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:51 EDT 2006
Hello cho,
ANALYSIS
vector/v.in.dxf/dxf_to_vect.c functions
dxf_to_vect (Begins at: 15 Ends at: 152)
Complexity:   |      37 |   *** | MONSTER |
CalledNBR:    |      44 |     * |         |
LOC:          |     138 |     * |         |
1 metric are OUT OF RANGE!
check_ext (Begins at: 154 Ends at: 170)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
set_entity (Begins at: 172 Ends at: 179)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
make_head (Begins at: 181 Ends at: 201)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
