[GRASS-QA] SOCCER LAB GRASS QA: 2 clones ( Dscreen.c list.c
get_row.c get_row.c put_row.c put_row.c vect.c areas.c draw.c
position.c get_row.c pad.c main.c main.c command.c ) 3
monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:52 EDT 2006
Hello glynn,
ANALYSIS
lib/driver/command.c functions
xalloc (Begins at: 58 Ends at: 67)
Complexity: | 2 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 10 | | OK |
metrics are OK
command_init (Begins at: 69 Ends at: 78)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 10 | | OK |
metrics are OK
LIB_command_get_input (Begins at: 80 Ends at: 83)
ParamNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
process_command (Begins at: 85 Ends at: 618)
Complexity: | 218 | *** | MONSTER |
CalledNBR: | 283 | *** | MONSTER |
LOC: | 534 | *** | MONSTER |
3 metric are OUT OF RANGE!
read1 (Begins at: 620 Ends at: 633)
Complexity: | 4 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 14 | | OK |
metrics are OK
get_command (Begins at: 635 Ends at: 661)
Complexity: | 7 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 27 | | OK |
metrics are OK
get1 (Begins at: 663 Ends at: 678)
Complexity: | 5 | | OK |
LOC: | 16 | | OK |
metrics are OK
rec (Begins at: 680 Ends at: 689)
Complexity: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
rectext (Begins at: 691 Ends at: 715)
LOC: | 25 | | OK |
metrics are OK
_send (Begins at: 717 Ends at: 733)
LOC: | 17 | | OK |
metrics are OK
sendtext (Begins at: 735 Ends at: 739)
LOC: | 5 | | OK |
metrics are OK
RESULT (Begins at: 741 Ends at: 749)
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
command_init xalloc
In lib/driver/command.c clones of xalloc are:
display/drivers/lib/command.c xalloc
In lib/driver/command.c clones of command_init are:
display/drivers/lib/command.c command_init
Threshold GRASS6 key metrics values at 2006-06-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
