[GRASS-QA] SOCCER LAB GRASS QA: 12 clones ( Dscreen.c list.c
get_row.c get_row.c put_row.c put_row.c vect.c areas.c draw.c
position.c get_row.c pad.c main.c main.c command.c parser.c
GS2.c gethead.c anim_support.c ) 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:54 EDT 2006
Hello glynn,
ANALYSIS
visualization/nviz/src/anim_support.c functions
Nset_interp_mode_cmd (Begins at: 32 Ends at: 74)
Complexity: | 4 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 43 | | OK |
metrics are OK
Nset_tension_cmd (Begins at: 76 Ends at: 121)
CalledNBR: | 2 | | OK |
LOC: | 46 | | OK |
metrics are OK
Nshowtension_start_cmd (Begins at: 123 Ends at: 140)
Complexity: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 18 | | OK |
metrics are OK
Nupdate_tension_cmd (Begins at: 142 Ends at: 159)
LOC: | 18 | | OK |
metrics are OK
Nshowtension_stop_cmd (Begins at: 161 Ends at: 195)
LOC: | 35 | | OK |
metrics are OK
Nupdate_frames_cmd (Begins at: 197 Ends at: 230)
LOC: | 34 | | OK |
metrics are OK
Nset_numsteps_cmd (Begins at: 232 Ends at: 268)
Complexity: | 3 | | OK |
LOC: | 37 | | OK |
metrics are OK
Nclear_keys_cmd (Begins at: 270 Ends at: 338)
LOC: | 69 | | OK |
metrics are OK
Nadd_key_cmd (Begins at: 340 Ends at: 437)
Complexity: | 17 | * | |
CalledNBR: | 19 | | OK |
LOC: | 98 | | OK |
metrics are OK
Ndelete_key_cmd (Begins at: 439 Ends at: 486)
Complexity: | 5 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 48 | | OK |
metrics are OK
Nmove_key_cmd (Begins at: 488 Ends at: 537)
CalledNBR: | 7 | | OK |
LOC: | 50 | | OK |
metrics are OK
Ndo_framestep_cmd (Begins at: 539 Ends at: 580)
LOC: | 42 | | OK |
metrics are OK
Nshow_site_cmd (Begins at: 582 Ends at: 605)
LOC: | 24 | | OK |
metrics are OK
Nprint_keys_cmd (Begins at: 607 Ends at: 624)
LOC: | 18 | | OK |
metrics are OK
Nshow_vect_cmd (Begins at: 626 Ends at: 649)
LOC: | 24 | | OK |
metrics are OK
Nshow_vol_cmd (Begins at: 651 Ends at: 674)
LOC: | 24 | | OK |
metrics are OK
Nshow_lab_cmd (Begins at: 676 Ends at: 699)
LOC: | 24 | | OK |
metrics are OK
Nshow_path_cmd (Begins at: 702 Ends at: 739)
LOC: | 38 | | OK |
metrics are OK
Nwrite_rgb_cmd (Begins at: 741 Ends at: 772)
LOC: | 32 | | OK |
metrics are OK
Nwrite_ppm_cmd (Begins at: 774 Ends at: 805)
LOC: | 32 | | OK |
metrics are OK
Nwrite_tif_cmd (Begins at: 807 Ends at: 824)
LOC: | 18 | | OK |
metrics are OK
Noff_screen_cmd (Begins at: 827 Ends at: 863)
CalledNBR: | 4 | | OK |
LOC: | 37 | | OK |
metrics are OK
Ninit_mpeg_cmd (Begins at: 869 Ends at: 889)
LOC: | 21 | | OK |
metrics are OK
Nwrite_mpeg_frame_cmd (Begins at: 894 Ends at: 911)
LOC: | 18 | | OK |
metrics are OK
Nclose_mpeg_cmd (Begins at: 916 Ends at: 933)
LOC: | 18 | | OK |
metrics are OK
Clone analysis:
This file has 12 potentially cloned functions:
Nclose_mpeg_cmd Nwrite_mpeg_frame_cmd Nwrite_tif_cmd Nprint_keys_cmd Nupdate_tension_cmd Nshowtension_start_cmd Nshow_lab_cmd Nshow_vol_cmd Nshow_vect_cmd Nshow_site_cmd Nwrite_ppm_cmd Nwrite_rgb_cmd
In visualization/nviz/src/anim_support.c clones of Nshow_vol_cmd are:
visualization/nviz/src/anim_support.c Nshow_lab_cmd
visualization/nviz/src/anim_support.c Nshow_vect_cmd
visualization/nviz/src/anim_support.c Nshow_site_cmd
In visualization/nviz/src/anim_support.c clones of Nclose_mpeg_cmd are:
visualization/nviz/src/anim_support.c Nwrite_mpeg_frame_cmd
visualization/nviz/src/anim_support.c Nwrite_tif_cmd
visualization/nviz/src/anim_support.c Nprint_keys_cmd
visualization/nviz/src/anim_support.c Nupdate_tension_cmd
visualization/nviz/src/anim_support.c Nshowtension_start_cmd
In visualization/nviz/src/anim_support.c clones of Nwrite_tif_cmd are:
visualization/nviz/src/anim_support.c Nclose_mpeg_cmd
In visualization/nviz/src/anim_support.c clones of Nwrite_ppm_cmd are:
visualization/nviz/src/anim_support.c Nwrite_rgb_cmd
In visualization/nviz/src/anim_support.c clones of Nwrite_rgb_cmd are:
visualization/nviz/src/anim_support.c Nwrite_ppm_cmd
In visualization/nviz/src/anim_support.c clones of Nprint_keys_cmd are:
In visualization/nviz/src/anim_support.c clones of Nshow_lab_cmd are:
visualization/nviz/src/anim_support.c Nshow_vol_cmd
In visualization/nviz/src/anim_support.c clones of Nshow_vect_cmd are:
In visualization/nviz/src/anim_support.c clones of Nupdate_tension_cmd are:
In visualization/nviz/src/anim_support.c clones of Nshow_site_cmd are:
In visualization/nviz/src/anim_support.c clones of Nshowtension_start_cmd are:
In visualization/nviz/src/anim_support.c clones of Nwrite_mpeg_frame_cmd are:
Threshold GRASS6 key metrics values at 2006-06-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
