[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:46 EDT 2006
Hello brad,
ANALYSIS
raster/r.carve/lobf.c functions
pg_init (Begins at: 12 Ends at: 16)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
pg_y_from_x (Begins at: 22 Ends at: 25)
LOC:          |       4 |       |      OK |
metrics are OK
pg_addpt (Begins at: 31 Ends at: 69)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
pg_getpoints (Begins at: 75 Ends at: 78)
LOC:          |       4 |       |      OK |
metrics are OK
pg_getpoints_reversed (Begins at: 84 Ends at: 101)
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
