[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:53 EDT 2006
Hello glynn,
ANALYSIS
lib/gis/location.c functions
G_location_path (Begins at: 41 Ends at: 66)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
G_location (Begins at: 69 Ends at: 72)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
G__location_path (Begins at: 75 Ends at: 95)
CalledNBR:    |       6 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
