[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( Dscreen.c ) 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:44 EDT 2006
Hello brad,
ANALYSIS
lib/D/Dscreen.c functions
Dscreen (Begins at: 12 Ends at: 19)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  Dscreen
In lib/D/Dscreen.c clones of  Dscreen are:
	db/drivers/sqlite/db.c  db__driver_close_database
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
