[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( Dscreen.c list.c
get_row.c get_row.c put_row.c put_row.c vect.c areas.c draw.c
position.c get_row.c pad.c main.c main.c command.c parser.c
GS2.c gethead.c anim_support.c draw.c position.c
site_attr_commands.c site_highlight_commands.c
togl_flythrough.c parser.c raster.c line.c main.c
writeascii.c ) 1 monsters and 4 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:56 EDT 2006
Hello soeren,
ANALYSIS
raster/r.out.vtk/writeascii.c functions
GetRasterValueAsDouble (Begins at: 33 Ends at: 63)
Complexity: | 7 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 31 | | OK |
metrics are OK
writeVTKNormalHeader (Begins at: 69 Ends at: 95)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 27 | | OK |
metrics are OK
writeVTKStructuredElevationHeader (Begins at: 101 Ends at: 112)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 12 | | OK |
metrics are OK
writeVTKPolygonalElevationHeader (Begins at: 117 Ends at: 127)
CalledNBR: | 7 | | OK |
LOC: | 11 | | OK |
metrics are OK
writeVTKCellDataHeader (Begins at: 132 Ends at: 136)
LOC: | 5 | | OK |
metrics are OK
writeVTKPointDataHeader (Begins at: 141 Ends at: 145)
LOC: | 5 | | OK |
metrics are OK
writeVTKStructuredCoordinates (Begins at: 152 Ends at: 198)
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 13 | | OK |
LOC: | 47 | | OK |
at least 1 values are close to an outlier please consider revising code
writeVTKPolygonalCoordinates (Begins at: 204 Ends at: 309)
Complexity: | 6 | | OK |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 23 | | OK |
LOC: | 106 | | OK |
1 metric are OUT OF RANGE!
writeVTKData (Begins at: 315 Ends at: 357)
ParamNBR: | 6 | * | |
CalledNBR: | 16 | | OK |
LOC: | 43 | | OK |
writeVTKRGBImageData (Begins at: 365 Ends at: 424)
Complexity: | 5 | | OK |
CalledNBR: | 29 | | OK |
LOC: | 60 | | OK |
writeVTKVectorData (Begins at: 431 Ends at: 482)
Complexity: | 4 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 52 | | OK |
Clone analysis:
This file has 1 potentially cloned functions:
In raster/r.out.vtk/writeascii.c clones of GetRasterValueAsDouble are:
raster3d/r3.out.vtk/writeVTKData.c GetRasterValueAsDouble
Threshold GRASS6 key metrics values at 2006-06-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
