[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:52 EDT 2006
Hello cho,
ANALYSIS
vector/v.in.dxf/write_vect.c functions
write_vect (Begins at: 14 Ends at: 71)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      30 |       |      OK |
LOC:          |      58 |       |      OK |
at least 1 values are close to an outlier please consider revising code
write_done (Begins at: 73 Ends at: 117)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
get_field_cat (Begins at: 119 Ends at: 209)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |      91 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
