[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca
Fri Jun 16 07:57:50 EDT 2006
Hello markus,
ANALYSIS
db/drivers/postgres/db.c functions
db__driver_open_database (Begins at: 8 Ends at: 147)
Complexity: | 25 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 73 | ** | Warning |
LOC: | 140 | * | |
at least 2 values are close to an outlier please consider revising code
db__driver_close_database (Begins at: 149 Ends at: 154)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
