[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Jun 16 07:57:50 EDT 2006
Hello markus,
ANALYSIS
db/drivers/postgres/fetch.c functions
db__driver_fetch (Begins at: 11 Ends at: 175)
Complexity:   |      34 |    ** | Warning |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      51 |     * |         |
LOC:          |     165 |     * |         |
at least 1 values are close to an outlier please consider revising code
db__driver_get_num_rows (Begins at: 178 Ends at: 195)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-16 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
