[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( writeascii.c ) 1
monsters and 4 warnings
cvs at proxy.soccerlab.polymtl.ca
Fri Jun 16 11:35:31 EDT 2006
Hello soeren,
ANALYSIS
raster/r.out.vtk/writeascii.c functions
GetRasterValueAsDouble (Begins at: 33 Ends at: 63)
Complexity: | 7 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 31 | | OK |
metrics are OK
writeVTKNormalHeader (Begins at: 69 Ends at: 95)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 27 | | OK |
metrics are OK
writeVTKStructuredElevationHeader (Begins at: 101 Ends at: 112)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 12 | | OK |
metrics are OK
writeVTKPolygonalElevationHeader (Begins at: 117 Ends at: 127)
CalledNBR: | 7 | | OK |
LOC: | 11 | | OK |
metrics are OK
writeVTKCellDataHeader (Begins at: 132 Ends at: 136)
LOC: | 5 | | OK |
metrics are OK
writeVTKPointDataHeader (Begins at: 141 Ends at: 145)
LOC: | 5 | | OK |
metrics are OK
writeVTKStructuredCoordinates (Begins at: 152 Ends at: 200)
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 13 | | OK |
LOC: | 49 | | OK |
at least 1 values are close to an outlier please consider revising code
writeVTKPolygonalCoordinates (Begins at: 206 Ends at: 313)
Complexity: | 6 | | OK |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 23 | | OK |
LOC: | 108 | | OK |
1 metric are OUT OF RANGE!
writeVTKData (Begins at: 319 Ends at: 361)
ParamNBR: | 6 | * | |
CalledNBR: | 16 | | OK |
LOC: | 43 | | OK |
writeVTKRGBImageData (Begins at: 369 Ends at: 428)
Complexity: | 5 | | OK |
CalledNBR: | 29 | | OK |
LOC: | 60 | | OK |
writeVTKVectorData (Begins at: 435 Ends at: 486)
Complexity: | 4 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 52 | | OK |
Clone analysis:
This file has 1 potentially cloned functions:
In raster/r.out.vtk/writeascii.c clones of GetRasterValueAsDouble are:
raster3d/r3.out.vtk/writeVTKData.c GetRasterValueAsDouble
Threshold GRASS6 key metrics values at 2006-06-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
