[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 7 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Jun 16 11:35:31 EDT 2006
Hello soeren,
ANALYSIS
vector/v.out.vtk/writeVTK.c functions
writeVTKPoints (Begins at: 32 Ends at: 282)
Complexity:   |      36 |   *** | MONSTER |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      33 |     * |         |
LOC:          |     251 |   *** | MONSTER |
at least 3 values are close to an outlier please consider revising code
writeVTKCells (Begins at: 288 Ends at: 445)
Complexity:   |      28 |    ** | Warning |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      29 |       |      OK |
LOC:          |     158 |     * |         |
at least 1 values are close to an outlier please consider revising code
writeVTKCatData (Begins at: 450 Ends at: 544)
Complexity:   |      19 |     * |         |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      23 |       |      OK |
LOC:          |      95 |       |      OK |
writeVTKDBData (Begins at: 546 Ends at: 552)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
writeVTK (Begins at: 557 Ends at: 615)
CalledNBR:    |       9 |       |      OK |
LOC:          |      59 |       |      OK |
writePointCoordinates (Begins at: 620 Ends at: 640)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-16 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
