[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Sat Jun 17 04:52:43 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.vpoints/colors.c functions
set_colors (Begins at: 21 Ends at: 26)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
set_menu_colors (Begins at: 28 Ends at: 65)
CalledNBR: | 16 | | OK |
LOC: | 38 | | OK |
metrics are OK
cursor_color (Begins at: 67 Ends at: 87)
LOC: | 21 | | OK |
metrics are OK
set_blue (Begins at: 89 Ends at: 93)
LOC: | 5 | | OK |
metrics are OK
set_gray (Begins at: 95 Ends at: 99)
LOC: | 5 | | OK |
metrics are OK
set_green (Begins at: 101 Ends at: 105)
LOC: | 5 | | OK |
metrics are OK
set_red (Begins at: 107 Ends at: 111)
LOC: | 5 | | OK |
metrics are OK
set_white (Begins at: 113 Ends at: 117)
LOC: | 5 | | OK |
metrics are OK
set_yellow (Begins at: 119 Ends at: 123)
LOC: | 5 | | OK |
metrics are OK
set_cur_clr (Begins at: 125 Ends at: 160)
Complexity: | 8 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 36 | | OK |
metrics are OK
get_vector_color (Begins at: 162 Ends at: 180)
LOC: | 19 | | OK |
metrics are OK
setmap_blue (Begins at: 182 Ends at: 185)
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
setmap_gray (Begins at: 187 Ends at: 190)
LOC: | 4 | | OK |
metrics are OK
setmap_green (Begins at: 192 Ends at: 195)
LOC: | 4 | | OK |
metrics are OK
setmap_red (Begins at: 197 Ends at: 200)
LOC: | 4 | | OK |
metrics are OK
setmap_white (Begins at: 202 Ends at: 205)
LOC: | 4 | | OK |
metrics are OK
setmap_yellow (Begins at: 207 Ends at: 210)
LOC: | 4 | | OK |
metrics are OK
done (Begins at: 212 Ends at: 215)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-17 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
