[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( target.c ) 0 monsters
and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Sat Jun 17 05:16:55 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.vpoints/target.c functions
get_target (Begins at: 10 Ends at: 50)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 41 | | OK |
metrics are OK
select_current_env (Begins at: 52 Ends at: 62)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 11 | | OK |
metrics are OK
select_target_env (Begins at: 64 Ends at: 74)
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
get_target
In imagery/i.vpoints/target.c clones of get_target are:
imagery/i.points/target.c get_target
Threshold GRASS6 key metrics values at 2006-06-17 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
