[GRASS-QA] SOCCER LAB GRASS QA: no clones 6 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sat Jun 17 09:04:45 EDT 2006
Hello markus,
ANALYSIS
lib/external/shapelib/shpopen.c functions
cvsid_aw (Begins at: 201 Ends at: 201)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       1 |       |      OK |
metrics are OK
SwapWord (Begins at: 231 Ends at: 250)
CalledNBR:    |       0 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
SfRealloc (Begins at: 252 Ends at: 266)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
SHPWriteHeader (Begins at: 268 Ends at: 396)
Complexity:   |      18 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      35 |     * |         |
LOC:          |     129 |     * |         |
metrics are OK
SHPOpen (Begins at: 399 Ends at: 636)
Complexity:   |      21 |     * |         |
CalledNBR:    |      67 |    ** | Warning |
LOC:          |     238 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
SHPClose (Begins at: 645 Ends at: 672)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
SHPGetInfo (Begins at: 681 Ends at: 710)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       5 |     * |         |
LOC:          |      30 |       |      OK |
metrics are OK
SHPCreate (Begins at: 713 Ends at: 846)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |     134 |     * |         |
metrics are OK
_SHPSetBounds (Begins at: 848 Ends at: 870)
CalledNBR:    |       8 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
SHPComputeExtents (Begins at: 873 Ends at: 908)
LOC:          |      36 |       |      OK |
metrics are OK
SHPCreateObject (Begins at: 911 Ends at: 1033)
Complexity:   |      10 |       |      OK |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      11 |       |      OK |
LOC:          |     123 |     * |         |
1 metric are OUT OF RANGE!
SHPCreateSimpleObject (Begins at: 1036 Ends at: 1050)
LOC:          |      15 |       |      OK |
metrics are OK
SHPWriteObject (Begins at: 1053 Ends at: 1428)
Complexity:   |      47 |   *** | MONSTER |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      68 |    ** | Warning |
LOC:          |     376 |   *** | MONSTER |
2 metric are OUT OF RANGE!
SHPReadObject (Begins at: 1431 Ends at: 1763)
Complexity:   |      48 |   *** | MONSTER |
CalledNBR:    |      86 |   *** | MONSTER |
LOC:          |     333 |   *** | MONSTER |
3 metric are OUT OF RANGE!
SHPTypeName (Begins at: 1770 Ends at: 1820)
Complexity:   |      17 |     * |         |
LOC:          |      51 |       |      OK |
metrics are OK
SHPPartTypeName (Begins at: 1827 Ends at: 1853)
Complexity:   |       9 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
SHPDestroyObject (Begins at: 1860 Ends at: 1888)
Complexity:   |       8 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
SHPRewindObject (Begins at: 1891 Ends at: 2035)
Complexity:   |      12 |       |      OK |
LOC:          |     145 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-17 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
