[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue Jun 20 06:42:42 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.vpoints/drawvect.c functions
plotvect (Begins at: 24 Ends at: 27)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
zoomvect (Begins at: 29 Ends at: 32)
LOC: | 4 | | OK |
metrics are OK
re_fresh_vect (Begins at: 34 Ends at: 37)
LOC: | 4 | | OK |
metrics are OK
warpvect (Begins at: 39 Ends at: 42)
ParamNBR: | 3 | | OK |
LOC: | 4 | | OK |
metrics are OK
drawvect (Begins at: 45 Ends at: 275)
Complexity: | 22 | * | |
ParamNBR: | 5 | * | |
CalledNBR: | 63 | ** | Warning |
LOC: | 231 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
choose_vectfile (Begins at: 277 Ends at: 280)
ParamNBR: | 2 | | OK |
LOC: | 4 | | OK |
metrics are OK
get_clr_name (Begins at: 282 Ends at: 311)
Complexity: | 8 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 30 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-20 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
