[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.vpoints/analyze.c |6 clones ( analyze.c )| 0 monsters | 3 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Jun 23 04:11:41 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.vpoints/analyze.c functions
do_1st (Begins at: 64 Ends at: 72)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
do_2nd (Begins at: 74 Ends at: 82)
LOC:          |       9 |       |      OK |
metrics are OK
do_3rd (Begins at: 84 Ends at: 92)
LOC:          |       9 |       |      OK |
metrics are OK
delete_mark (Begins at: 94 Ends at: 111)
CalledNBR:    |       4 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
delete_control_point (Begins at: 113 Ends at: 139)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
do_warp (Begins at: 143 Ends at: 164)
Complexity:   |       1 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
no_warp (Begins at: 166 Ends at: 169)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
warp (Begins at: 171 Ends at: 175)
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
rast_redraw (Begins at: 177 Ends at: 182)
LOC:          |       6 |       |      OK |
metrics are OK
uparrow (Begins at: 185 Ends at: 191)
LOC:          |       7 |       |      OK |
metrics are OK
downarrow (Begins at: 193 Ends at: 199)
LOC:          |       7 |       |      OK |
metrics are OK
pick (Begins at: 201 Ends at: 261)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
done (Begins at: 263 Ends at: 267)
LOC:          |       5 |       |      OK |
metrics are OK
cancel_which (Begins at: 269 Ends at: 281)
CalledNBR:    |       3 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
inbox (Begins at: 283 Ends at: 286)
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
dotext (Begins at: 288 Ends at: 302)
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      15 |       |      OK |
at least 1 values are close to an outlier please consider revising code
compute_transformation (Begins at: 304 Ends at: 378)
CalledNBR:    |       8 |       |      OK |
LOC:          |      75 |       |      OK |
metrics are OK
to_file (Begins at: 380 Ends at: 406)
CalledNBR:    |      10 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
askfile (Begins at: 408 Ends at: 429)
Complexity:   |       5 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
to_printer (Begins at: 431 Ends at: 442)
CalledNBR:    |       6 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
do_report (Begins at: 444 Ends at: 488)
CalledNBR:    |      20 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
printcentered (Begins at: 490 Ends at: 507)
LOC:          |      18 |       |      OK |
metrics are OK
show_point (Begins at: 509 Ends at: 520)
LOC:          |      12 |       |      OK |
metrics are OK
get_order (Begins at: 522 Ends at: 540)
LOC:          |      19 |       |      OK |
metrics are OK
analyze (Begins at: 542 Ends at: 777)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      60 |    ** | Warning |
LOC:          |     236 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file has 6 potentially cloned functions:
  dotext  to_file  printcentered  askfile  delete_mark  do_report
In imagery/i.vpoints/analyze.c clones of  printcentered are:
	imagery/i.points/analyze.c  printcentered
	imagery/i.ortho.photo/photo.2target/analyze.c  printcentered
	imagery/i.ortho.photo/photo.2image/analyze.c  printcentered
In imagery/i.vpoints/analyze.c clones of  do_report are:
	imagery/i.points/analyze.c  do_report
	imagery/i.ortho.photo/photo.2image/analyze.c  do_report
In imagery/i.vpoints/analyze.c clones of  delete_mark are:
	lib/gis/color_org.c  G__organize_colors
In imagery/i.vpoints/analyze.c clones of  to_file are:
	imagery/i.points/analyze.c  to_file
	imagery/i.ortho.photo/photo.2target/analyze.c  to_file
	imagery/i.ortho.photo/photo.2image/analyze.c  to_file
In imagery/i.vpoints/analyze.c clones of  askfile are:
	imagery/i.points/analyze.c  askfile
	imagery/i.ortho.photo/photo.2target/analyze.c  askfile
	imagery/i.ortho.photo/photo.2image/analyze.c  askfile
In imagery/i.vpoints/analyze.c clones of  dotext are:
	imagery/i.points/analyze.c  dotext
	imagery/i.ortho.photo/photo.2image/use_camera.c  dotext
	imagery/i.ortho.photo/photo.2image/mark.c  dotext
Threshold GRASS6 key metrics values at 2006-06-23 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
