[GRASS-QA] GRASS QA: paul | ./grass6/imagery/i.find/main.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 27 09:54:14 EDT 2006
Hello paul,
ANALYSIS
imagery/i.find/main.c functions
main (Begins at: 38 Ends at: 83)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
find (Begins at: 86 Ends at: 131)
Complexity:   |       6 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-27 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
