[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.points/curses.c |7
clones ( curses.c curses.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 04:11:12 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.points/curses.c functions
make_window (Begins at: 11 Ends at: 31)
Complexity: | 2 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 21 | | OK |
metrics are OK
Begin_curses (Begins at: 33 Ends at: 55)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 23 | | OK |
metrics are OK
End_curses (Begins at: 57 Ends at: 66)
CalledNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
Suspend_curses (Begins at: 68 Ends at: 76)
CalledNBR: | 4 | | OK |
LOC: | 9 | | OK |
metrics are OK
Resume_curses (Begins at: 78 Ends at: 86)
LOC: | 9 | | OK |
metrics are OK
Curses_allow_interrupts (Begins at: 88 Ends at: 97)
LOC: | 10 | | OK |
metrics are OK
Curses_clear_window (Begins at: 99 Ends at: 114)
Complexity: | 3 | | OK |
LOC: | 16 | | OK |
metrics are OK
Curses_outline_window (Begins at: 116 Ends at: 146)
Complexity: | 4 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 31 | | OK |
metrics are OK
Curses_write_window (Begins at: 148 Ends at: 175)
Complexity: | 6 | | OK |
LOC: | 28 | | OK |
metrics are OK
Curses_replot_screen (Begins at: 179 Ends at: 188)
LOC: | 10 | | OK |
metrics are OK
Curses_prompt_gets (Begins at: 190 Ends at: 238)
ParamNBR: | 2 | | OK |
LOC: | 49 | | OK |
metrics are OK
Beep (Begins at: 241 Ends at: 247)
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
Curses_getch (Begins at: 250 Ends at: 282)
Complexity: | 7 | | OK |
LOC: | 33 | | OK |
metrics are OK
Clone analysis:
This file has 7 potentially cloned functions:
Curses_outline_window make_window Curses_getch Curses_clear_window Curses_write_window Curses_prompt_gets End_curses
In imagery/i.points/curses.c clones of Curses_outline_window are:
imagery/i.vpoints/curses.c Curses_outline_window
imagery/i.ortho.photo/photo.2image/curses.c Curses_outline_window
In imagery/i.points/curses.c clones of Curses_prompt_gets are:
imagery/i.vpoints/curses.c Curses_prompt_gets
imagery/i.ortho.photo/photo.2image/curses.c Curses_prompt_gets
In imagery/i.points/curses.c clones of make_window are:
imagery/i.vpoints/curses.c make_window
imagery/i.ortho.photo/photo.2image/curses.c make_window
In imagery/i.points/curses.c clones of Curses_getch are:
imagery/i.vpoints/curses.c Curses_getch
imagery/i.ortho.photo/photo.2target/curses.c Curses_getch
imagery/i.ortho.photo/photo.2image/curses.c Curses_getch
imagery/i.class/curses.c Curses_getch
In imagery/i.points/curses.c clones of Curses_write_window are:
imagery/i.vpoints/curses.c Curses_write_window
imagery/i.ortho.photo/photo.2image/curses.c Curses_write_window
In imagery/i.points/curses.c clones of Curses_clear_window are:
imagery/i.vpoints/curses.c Curses_clear_window
imagery/i.ortho.photo/photo.2image/curses.c Curses_clear_window
In imagery/i.points/curses.c clones of End_curses are:
imagery/i.ortho.photo/photo.2target/colors.c set_colors
imagery/i.ortho.photo/photo.2image/curses.c End_curses
Threshold GRASS6 key metrics values at 2006-06-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
