[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.colors/curses.c
|no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 04:11:11 EDT 2006
Hello hamish,
ANALYSIS
display/d.colors/curses.c functions
Initialize_curses (Begins at: 29 Ends at: 49)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 21 | | OK |
metrics are OK
Close_curses (Begins at: 52 Ends at: 60)
CalledNBR: | 4 | | OK |
LOC: | 9 | | OK |
metrics are OK
Write_cats (Begins at: 63 Ends at: 114)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 52 | | OK |
metrics are OK
Write_menu (Begins at: 117 Ends at: 138)
CalledNBR: | 29 | | OK |
LOC: | 22 | | OK |
metrics are OK
Write_status (Begins at: 141 Ends at: 182)
Complexity: | 3 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 22 | | OK |
LOC: | 42 | | OK |
metrics are OK
Write_message (Begins at: 185 Ends at: 195)
CalledNBR: | 6 | | OK |
LOC: | 11 | | OK |
metrics are OK
Clear_message (Begins at: 198 Ends at: 204)
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
Clear_menu (Begins at: 207 Ends at: 213)
LOC: | 7 | | OK |
metrics are OK
Write_menu_line (Begins at: 216 Ends at: 225)
CalledNBR: | 5 | | OK |
LOC: | 10 | | OK |
metrics are OK
Replot_screen (Begins at: 228 Ends at: 233)
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
Get_curses_text (Begins at: 236 Ends at: 272)
Complexity: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 37 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-06-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
