[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.vpoints/curses.c
|7 clones ( curses.c curses.c curses.c )| 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 04:11:12 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.vpoints/curses.c functions
make_window (Begins at: 10 Ends at: 30)
Complexity: | 2 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 21 | | OK |
metrics are OK
Begin_curses (Begins at: 32 Ends at: 53)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 22 | | OK |
metrics are OK
End_curses (Begins at: 55 Ends at: 63)
CalledNBR: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
Suspend_curses (Begins at: 65 Ends at: 73)
CalledNBR: | 4 | | OK |
LOC: | 9 | | OK |
metrics are OK
Resume_curses (Begins at: 75 Ends at: 83)
LOC: | 9 | | OK |
metrics are OK
Curses_allow_interrupts (Begins at: 85 Ends at: 94)
LOC: | 10 | | OK |
metrics are OK
Curses_clear_window (Begins at: 96 Ends at: 111)
Complexity: | 3 | | OK |
LOC: | 16 | | OK |
metrics are OK
Curses_outline_window (Begins at: 113 Ends at: 143)
Complexity: | 4 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 31 | | OK |
metrics are OK
Curses_write_window (Begins at: 145 Ends at: 172)
Complexity: | 6 | | OK |
LOC: | 28 | | OK |
metrics are OK
Curses_replot_screen (Begins at: 175 Ends at: 184)
LOC: | 10 | | OK |
metrics are OK
Curses_prompt_gets (Begins at: 186 Ends at: 237)
ParamNBR: | 2 | | OK |
LOC: | 52 | | OK |
metrics are OK
Beep (Begins at: 239 Ends at: 245)
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
Curses_getch (Begins at: 247 Ends at: 279)
Complexity: | 7 | | OK |
LOC: | 33 | | OK |
metrics are OK
Clone analysis:
This file has 7 potentially cloned functions:
Curses_outline_window make_window Curses_getch Curses_clear_window Begin_curses Curses_write_window Curses_prompt_gets
In imagery/i.vpoints/curses.c clones of Curses_outline_window are:
imagery/i.points/curses.c Curses_outline_window
imagery/i.ortho.photo/photo.2image/curses.c Curses_outline_window
In imagery/i.vpoints/curses.c clones of Curses_prompt_gets are:
imagery/i.points/curses.c Curses_prompt_gets
imagery/i.ortho.photo/photo.2image/curses.c Curses_prompt_gets
In imagery/i.vpoints/curses.c clones of make_window are:
imagery/i.points/curses.c make_window
imagery/i.ortho.photo/photo.2image/curses.c make_window
In imagery/i.vpoints/curses.c clones of Curses_getch are:
imagery/i.points/curses.c Curses_getch
imagery/i.ortho.photo/photo.2target/curses.c Curses_getch
imagery/i.ortho.photo/photo.2image/curses.c Curses_getch
imagery/i.class/curses.c Curses_getch
In imagery/i.vpoints/curses.c clones of Curses_write_window are:
imagery/i.points/curses.c Curses_write_window
imagery/i.ortho.photo/photo.2image/curses.c Curses_write_window
In imagery/i.vpoints/curses.c clones of Begin_curses are:
imagery/i.ortho.photo/photo.2target/curses.c Begin_curses
imagery/i.ortho.photo/photo.2image/curses.c Begin_curses
imagery/i.class/curses.c Begin_curses
In imagery/i.vpoints/curses.c clones of Curses_clear_window are:
imagery/i.points/curses.c Curses_clear_window
imagery/i.ortho.photo/photo.2image/curses.c Curses_clear_window
Threshold GRASS6 key metrics values at 2006-06-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
