[GRASS-QA] GRASS QA: hamish | ./grass6/imagery/i.vpoints/main.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 12:17:24 EDT 2006
Hello hamish,
ANALYSIS
imagery/i.vpoints/main.c functions
main (Begins at: 29 Ends at: 160)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      54 |     * |         |
LOC:          |     132 |     * |         |
metrics are OK
quit (Begins at: 162 Ends at: 185)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
error (Begins at: 187 Ends at: 213)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-28 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
