[GRASS-QA] GRASS QA: cho | ./grass6/display/d.zoom/pan.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Jun 28 22:56:31 EDT 2006
Hello cho,
ANALYSIS
display/d.zoom/pan.c functions
do_pan (Begins at: 14 Ends at: 44)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
pan_window (Begins at: 48 Ends at: 93)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-28 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
