[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( colors.c io.c ) 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed May 3 03:28:27 EDT 2006
Hello hamish,
ANALYSIS
lib/raster/io.c functions
_get (Begins at: 34 Ends at: 51)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 18 | | OK |
metrics are OK
flushout (Begins at: 53 Ends at: 62)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 10 | | OK |
metrics are OK
_send_ident (Begins at: 64 Ends at: 75)
LOC: | 12 | | OK |
metrics are OK
_send_char (Begins at: 77 Ends at: 86)
LOC: | 10 | | OK |
metrics are OK
_send_char_array (Begins at: 88 Ends at: 94)
LOC: | 7 | | OK |
metrics are OK
_send_int_array (Begins at: 96 Ends at: 99)
Complexity: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
_send_float_array (Begins at: 101 Ends at: 104)
LOC: | 4 | | OK |
metrics are OK
_send_int (Begins at: 106 Ends at: 109)
LOC: | 4 | | OK |
metrics are OK
_send_float (Begins at: 111 Ends at: 114)
LOC: | 4 | | OK |
metrics are OK
_send_text (Begins at: 116 Ends at: 119)
CalledNBR: | 2 | | OK |
LOC: | 4 | | OK |
metrics are OK
_get_char (Begins at: 121 Ends at: 127)
LOC: | 7 | | OK |
metrics are OK
_get_int (Begins at: 129 Ends at: 135)
LOC: | 7 | | OK |
metrics are OK
_get_float (Begins at: 137 Ends at: 143)
LOC: | 7 | | OK |
metrics are OK
_get_text (Begins at: 145 Ends at: 155)
LOC: | 11 | | OK |
metrics are OK
_get_text_2 (Begins at: 157 Ends at: 181)
Complexity: | 4 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 25 | | OK |
metrics are OK
R__open_quiet (Begins at: 183 Ends at: 188)
CalledNBR: | 0 | | OK |
LOC: | 6 | | OK |
metrics are OK
sync_driver (Begins at: 190 Ends at: 243)
Complexity: | 8 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 54 | | OK |
metrics are OK
dead (Begins at: 245 Ends at: 248)
LOC: | 4 | | OK |
metrics are OK
_hold_signals (Begins at: 250 Ends at: 280)
ParamNBR: | 3 | | OK |
LOC: | 31 | | OK |
metrics are OK
R_stabilize (Begins at: 282 Ends at: 291)
CalledNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
R_kill_driver (Begins at: 293 Ends at: 311)
LOC: | 19 | | OK |
metrics are OK
R_close_driver (Begins at: 313 Ends at: 323)
LOC: | 11 | | OK |
metrics are OK
R_release_driver (Begins at: 325 Ends at: 333)
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
R_close_driver
In lib/raster/io.c clones of R_close_driver are:
lib/raster/pad.c R_pad_invent
Threshold GRASS6 key metrics values at 2006-05-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
