[GRASS-QA] SOCCER LAB GRASS QA: 2 clones ( main.c ) 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed May 3 06:01:31 EDT 2006
Hello markus,
ANALYSIS
raster/r.to.rast3/main.c functions
FatalError (Begins at: 48 Ends at: 67)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
SetParameters (Begins at: 72 Ends at: 89)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
RasterToG3D (Begins at: 96 Ends at: 167)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
main (Begins at: 173 Ends at: 320)
Complexity:   |      16 |     * |         |
CalledNBR:    |      44 |     * |         |
LOC:          |     148 |     * |         |
metrics are OK
OpenInputMap (Begins at: 327 Ends at: 342)
Complexity:   |       2 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
CloseInputMap (Begins at: 347 Ends at: 351)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  OpenInputMap  SetParameters
In raster/r.to.rast3/main.c clones of  OpenInputMap are:
	raster3d/r3.out.vtk/main.c  OpenInputMap
In raster/r.to.rast3/main.c clones of  SetParameters are:
	raster3d/base/r3.mask.main.c  setParams
Threshold GRASS6 key metrics values at 2006-05-03 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
