[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca
Wed May 3 10:19:10 EDT 2006
Hello cho,
ANALYSIS
vector/v.in.dxf/add_line.c functions
add_line (Begins at: 8 Ends at: 104)
Complexity: | 26 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 97 | | OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 78 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
