[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed May 3 10:19:10 EDT 2006
Hello cho,
ANALYSIS
vector/v.in.dxf/add_arc.c functions
add_arc (Begins at: 9 Ends at: 100)
Complexity:   |      23 |     * |         |
CalledNBR:    |      16 |       |      OK |
LOC:          |      92 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-03 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
