[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
    cvs at proxy.soccerlab.polymtl.ca
    Thu May  4 05:04:58 EDT 2006
Hello hamish,
ANALYSIS
display/d.graph/do_graph.c functions
set_graph_stuff (Begins at: 23 Ends at: 31)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
set_text_size (Begins at: 33 Ends at: 45)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
do_draw (Begins at: 47 Ends at: 73)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
do_move (Begins at: 75 Ends at: 93)
LOC:          |      19 |       |      OK |
metrics are OK
do_color (Begins at: 95 Ends at: 125)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
do_linewidth (Begins at: 127 Ends at: 140)
CalledNBR:    |       5 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
do_poly (Begins at: 143 Ends at: 200)
Complexity:   |       9 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
do_size (Begins at: 202 Ends at: 228)
LOC:          |      27 |       |      OK |
metrics are OK
do_text_rotate (Begins at: 230 Ends at: 243)
LOC:          |      14 |       |      OK |
metrics are OK
do_text (Begins at: 245 Ends at: 256)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
check_alloc (Begins at: 258 Ends at: 291)
CalledNBR:    |       4 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
do_icon (Begins at: 293 Ends at: 343)
CalledNBR:    |      18 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
do_symbol (Begins at: 345 Ends at: 433)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      34 |     * |         |
LOC:          |      89 |       |      OK |
metrics are OK
set_last_color (Begins at: 436 Ends at: 448)
ParamNBR:     |       4 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     255 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
