[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Fri May 5 19:38:31 EDT 2006
Hello brad,
ANALYSIS
lib/ogsf/gsd_img_ppm.c functions
GS_write_ppm (Begins at: 37 Ends at: 82)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 46 | | OK |
metrics are OK
GS_write_zoom (Begins at: 84 Ends at: 129)
ParamNBR: | 3 | | OK |
LOC: | 46 | | OK |
metrics are OK
gsd_init_mpeg (Begins at: 136 Ends at: 234)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 99 | | OK |
metrics are OK
gsd_write_mpegframe (Begins at: 241 Ends at: 296)
ParamNBR: | 0 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 56 | | OK |
metrics are OK
gsd_close_mpeg (Begins at: 302 Ends at: 334)
LOC: | 33 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 182 | 256 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
