[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Sat May 6 04:31:19 EDT 2006
Hello cedric,
ANALYSIS
general/g.parser/main.c functions
translate (Begins at: 32 Ends at: 39)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 8 | | OK |
metrics are OK
parse_toplevel (Begins at: 41 Ends at: 70)
Complexity: | 6 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 30 | | OK |
metrics are OK
parse_module (Begins at: 72 Ends at: 96)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 25 | | OK |
metrics are OK
parse_flag (Begins at: 98 Ends at: 139)
Complexity: | 7 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 42 | | OK |
metrics are OK
parse_type (Begins at: 141 Ends at: 156)
CalledNBR: | 4 | | OK |
LOC: | 16 | | OK |
metrics are OK
parse_boolean (Begins at: 158 Ends at: 170)
Complexity: | 3 | | OK |
LOC: | 13 | | OK |
metrics are OK
parse_option (Begins at: 172 Ends at: 255)
Complexity: | 14 | | OK |
CalledNBR: | 30 | | OK |
LOC: | 84 | | OK |
metrics are OK
main (Begins at: 257 Ends at: 401)
Complexity: | 16 | * | |
CalledNBR: | 38 | * | |
LOC: | 145 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
