[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( parser.c ) 1 monsters
and 7 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue May 9 15:36:52 EDT 2006
Hello cedric,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 183 Ends at: 199)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_define_flag (Begins at: 202 Ends at: 250)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 49 | | OK |
metrics are OK
G_define_option (Begins at: 253 Ends at: 306)
LOC: | 54 | | OK |
metrics are OK
G_define_standard_option (Begins at: 309 Ends at: 431)
Complexity: | 16 | * | |
CalledNBR: | 16 | | OK |
LOC: | 123 | * | |
metrics are OK
G_define_module (Begins at: 434 Ends at: 468)
CalledNBR: | 1 | | OK |
LOC: | 35 | | OK |
metrics are OK
G_parser (Begins at: 470 Ends at: 707)
Complexity: | 34 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 56 | ** | Warning |
LOC: | 238 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 710 Ends at: 755)
Complexity: | 5 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 46 | | OK |
metrics are OK
G_usage (Begins at: 757 Ends at: 917)
Complexity: | 31 | ** | Warning |
CalledNBR: | 42 | * | |
LOC: | 161 | * | |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 919 Ends at: 935)
Complexity: | 6 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_usage_xml (Begins at: 937 Ends at: 1135)
Complexity: | 25 | * | |
CalledNBR: | 62 | ** | Warning |
LOC: | 199 | ** | Warning |
G_usage_html (Begins at: 1137 Ends at: 1354)
Complexity: | 40 | *** | MONSTER |
CalledNBR: | 71 | ** | Warning |
LOC: | 218 | ** | Warning |
1 metric are OUT OF RANGE!
generate_tcl (Begins at: 1356 Ends at: 1427)
Complexity: | 9 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 72 | | OK |
metrics are OK
G_gui (Begins at: 1430 Ends at: 1452)
CalledNBR: | 8 | | OK |
LOC: | 23 | | OK |
metrics are OK
G_tcltk (Begins at: 1455 Ends at: 1470)
LOC: | 16 | | OK |
metrics are OK
show_options (Begins at: 1472 Ends at: 1501)
Complexity: | 4 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 30 | | OK |
metrics are OK
show (Begins at: 1503 Ends at: 1516)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
set_flag (Begins at: 1518 Ends at: 1545)
LOC: | 28 | | OK |
metrics are OK
contains (Begins at: 1550 Ends at: 1559)
LOC: | 10 | | OK |
metrics are OK
set_option (Begins at: 1561 Ends at: 1621)
CalledNBR: | 13 | | OK |
LOC: | 61 | | OK |
metrics are OK
check_opts (Begins at: 1623 Ends at: 1660)
LOC: | 38 | | OK |
metrics are OK
check_an_opt (Begins at: 1662 Ends at: 1704)
Complexity: | 10 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
check_int (Begins at: 1706 Ends at: 1772)
Complexity: | 13 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 67 | | OK |
metrics are OK
check_double (Begins at: 1774 Ends at: 1814)
LOC: | 41 | | OK |
metrics are OK
check_string (Begins at: 1816 Ends at: 1843)
Complexity: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
check_required (Begins at: 1845 Ends at: 1868)
LOC: | 24 | | OK |
metrics are OK
split_opts (Begins at: 1870 Ends at: 1933)
LOC: | 64 | | OK |
metrics are OK
check_multiple_opts (Begins at: 1935 Ends at: 1973)
CalledNBR: | 5 | | OK |
LOC: | 39 | | OK |
metrics are OK
check_overwrite (Begins at: 1976 Ends at: 2026)
CalledNBR: | 9 | | OK |
LOC: | 51 | | OK |
metrics are OK
interactive (Begins at: 2028 Ends at: 2056)
LOC: | 29 | | OK |
metrics are OK
interactive_flag (Begins at: 2058 Ends at: 2066)
LOC: | 9 | | OK |
metrics are OK
interactive_option (Begins at: 2068 Ends at: 2158)
Complexity: | 23 | * | |
CalledNBR: | 41 | * | |
LOC: | 91 | | OK |
metrics are OK
split_gisprompt (Begins at: 2160 Ends at: 2190)
LOC: | 31 | | OK |
metrics are OK
gis_prompt (Begins at: 2192 Ends at: 2237)
Complexity: | 11 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 46 | | OK |
metrics are OK
G_recreate_command (Begins at: 2239 Ends at: 2339)
CalledNBR: | 25 | | OK |
LOC: | 101 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
interactive_flag
In lib/gis/parser.c clones of interactive_flag are:
lib/gis/rm_colr.c G_remove_colr
Threshold GRASS6 key metrics values at 2006-05-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
