[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed May 10 10:59:40 EDT 2006
Hello paul,
ANALYSIS
lib/proj/convert.c functions
GPJ_grass_to_wkt (Begins at: 52 Ends at: 84)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
GPJ_grass_to_osr (Begins at: 86 Ends at: 225)
Complexity:   |      17 |     * |         |
CalledNBR:    |      57 |    ** | Warning |
LOC:          |     140 |     * |         |
at least 1 values are close to an outlier please consider revising code
GPJ_osr_to_grass (Begins at: 227 Ends at: 545)
Complexity:   |      35 |    ** | Warning |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      77 |    ** | Warning |
LOC:          |     319 |   *** | MONSTER |
1 metric are OUT OF RANGE!
GPJ_wkt_to_grass (Begins at: 548 Ends at: 569)
Complexity:   |       2 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
GPJ_set_csv_loc (Begins at: 575 Ends at: 600)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
GPJ_DatumNameMassage (Begins at: 630 Ends at: 677)
Complexity:   |       5 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-10 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
