[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( main.c ) 3 monsters and
0 warnings
cvs at proxy.soccerlab.polymtl.ca
Thu May 11 15:56:21 EDT 2006
Hello markus,
ANALYSIS
vector/v.lrs/v.lrs.create/main.c functions
main (Begins at: 79 Ends at: 768)
Complexity: | 60 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 204 | *** | MONSTER |
LOC: | 690 | *** | MONSTER |
3 metric are OUT OF RANGE!
cmp_along (Begins at: 770 Ends at: 782)
Complexity: | 5 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
cmp_along
In vector/v.lrs/v.lrs.create/main.c clones of cmp_along are:
imagery/i.class/edge_order.c edge_order
Threshold GRASS6 key metrics values at 2006-05-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
