[GRASS-QA] SOCCER LAB GRASS QA: no clones 2 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri May 12 03:33:09 EDT 2006
Hello cedric,
ANALYSIS
vector/v.in.ascii/points.c functions
is_int (Begins at: 12 Ends at: 20)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
is_double (Begins at: 24 Ends at: 46)
Complexity:   |       6 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
points_analyse (Begins at: 48 Ends at: 183)
Complexity:   |      17 |     * |         |
ParamNBR:     |      11 |   *** | MONSTER |
CalledNBR:    |      37 |     * |         |
LOC:          |     136 |     * |         |
1 metric are OUT OF RANGE!
points_to_bin (Begins at: 185 Ends at: 296)
Complexity:   |      14 |       |      OK |
ParamNBR:     |      13 |   *** | MONSTER |
CalledNBR:    |      51 |     * |         |
LOC:          |     112 |     * |         |
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-12 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
