[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( parser.c ) 1 monsters and 7 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sat May 13 18:01:46 EDT 2006
Hello cedric,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 183 Ends at: 199)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_define_flag (Begins at: 202 Ends at: 250)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
G_define_option (Begins at: 253 Ends at: 306)
LOC:          |      54 |       |      OK |
metrics are OK
G_define_standard_option (Begins at: 309 Ends at: 431)
Complexity:   |      16 |     * |         |
CalledNBR:    |      16 |       |      OK |
LOC:          |     123 |     * |         |
metrics are OK
G_define_module (Begins at: 434 Ends at: 468)
CalledNBR:    |       1 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
G_parser (Begins at: 470 Ends at: 705)
Complexity:   |      34 |    ** | Warning |
CalledNBR:    |      56 |    ** | Warning |
LOC:          |     236 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 708 Ends at: 753)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
G_usage (Begins at: 755 Ends at: 915)
Complexity:   |      31 |    ** | Warning |
CalledNBR:    |      42 |     * |         |
LOC:          |     161 |     * |         |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 917 Ends at: 933)
Complexity:   |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_usage_xml (Begins at: 935 Ends at: 1133)
Complexity:   |      25 |     * |         |
CalledNBR:    |      62 |    ** | Warning |
LOC:          |     199 |    ** | Warning |
G_usage_html (Begins at: 1135 Ends at: 1352)
Complexity:   |      40 |   *** | MONSTER |
CalledNBR:    |      71 |    ** | Warning |
LOC:          |     218 |    ** | Warning |
1 metric are OUT OF RANGE!
generate_tcl (Begins at: 1354 Ends at: 1425)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
G_gui (Begins at: 1428 Ends at: 1450)
CalledNBR:    |       8 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
G_tcltk (Begins at: 1453 Ends at: 1468)
LOC:          |      16 |       |      OK |
metrics are OK
show_options (Begins at: 1470 Ends at: 1499)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
show (Begins at: 1501 Ends at: 1514)
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
set_flag (Begins at: 1516 Ends at: 1543)
LOC:          |      28 |       |      OK |
metrics are OK
contains (Begins at: 1548 Ends at: 1557)
LOC:          |      10 |       |      OK |
metrics are OK
set_option (Begins at: 1559 Ends at: 1619)
CalledNBR:    |      13 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
check_opts (Begins at: 1621 Ends at: 1658)
LOC:          |      38 |       |      OK |
metrics are OK
check_an_opt (Begins at: 1660 Ends at: 1702)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
check_int (Begins at: 1704 Ends at: 1770)
Complexity:   |      13 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
check_double (Begins at: 1772 Ends at: 1812)
LOC:          |      41 |       |      OK |
metrics are OK
check_string (Begins at: 1814 Ends at: 1841)
Complexity:   |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
check_required (Begins at: 1843 Ends at: 1866)
LOC:          |      24 |       |      OK |
metrics are OK
split_opts (Begins at: 1868 Ends at: 1931)
LOC:          |      64 |       |      OK |
metrics are OK
check_multiple_opts (Begins at: 1933 Ends at: 1971)
CalledNBR:    |       5 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
check_overwrite (Begins at: 1974 Ends at: 2030)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
interactive (Begins at: 2032 Ends at: 2060)
LOC:          |      29 |       |      OK |
metrics are OK
interactive_flag (Begins at: 2062 Ends at: 2070)
LOC:          |       9 |       |      OK |
metrics are OK
interactive_option (Begins at: 2072 Ends at: 2162)
Complexity:   |      23 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |      91 |       |      OK |
metrics are OK
split_gisprompt (Begins at: 2164 Ends at: 2194)
LOC:          |      31 |       |      OK |
metrics are OK
gis_prompt (Begins at: 2196 Ends at: 2241)
CalledNBR:    |      20 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
G_recreate_command (Begins at: 2243 Ends at: 2343)
CalledNBR:    |      25 |       |      OK |
LOC:          |     101 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  interactive_flag
In lib/gis/parser.c clones of  interactive_flag are:
	lib/gis/rm_colr.c  G_remove_colr
Threshold GRASS6 key metrics values at 2006-05-13 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
