[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Tue May 16 17:05:36 EDT 2006
Hello cho,
ANALYSIS
display/d.vect/main.c functions
icon_files (Begins at: 32 Ends at: 78)
Complexity: | 8 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 47 | | OK |
metrics are OK
test_bg_color (Begins at: 81 Ends at: 96)
Complexity: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 16 | | OK |
metrics are OK
main (Begins at: 99 Ends at: 628)
Complexity: | 71 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 174 | *** | MONSTER |
LOC: | 530 | *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 180 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
