[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue May 23 10:39:42 EDT 2006
Hello radim,
ANALYSIS
lib/db/dbmi_driver/driver.c functions
db_driver (Begins at: 21 Ends at: 151)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      39 |     * |         |
LOC:          |     131 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
