[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( parser.c ) 1 monsters and 7 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed May 24 03:30:29 EDT 2006
Hello hamish,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 200 Ends at: 216)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_define_flag (Begins at: 219 Ends at: 267)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
G_define_option (Begins at: 270 Ends at: 323)
LOC:          |      54 |       |      OK |
metrics are OK
G_define_standard_option (Begins at: 326 Ends at: 448)
Complexity:   |      16 |     * |         |
CalledNBR:    |      16 |       |      OK |
LOC:          |     123 |     * |         |
metrics are OK
G_define_module (Begins at: 451 Ends at: 485)
CalledNBR:    |       1 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
G_parser (Begins at: 487 Ends at: 722)
Complexity:   |      34 |    ** | Warning |
CalledNBR:    |      56 |    ** | Warning |
LOC:          |     236 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 725 Ends at: 770)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
G_usage (Begins at: 772 Ends at: 933)
Complexity:   |      31 |    ** | Warning |
CalledNBR:    |      42 |     * |         |
LOC:          |     162 |     * |         |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 935 Ends at: 951)
Complexity:   |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_usage_xml (Begins at: 953 Ends at: 1151)
Complexity:   |      25 |     * |         |
CalledNBR:    |      62 |    ** | Warning |
LOC:          |     199 |    ** | Warning |
G_usage_html (Begins at: 1153 Ends at: 1369)
Complexity:   |      40 |   *** | MONSTER |
CalledNBR:    |      71 |    ** | Warning |
LOC:          |     217 |    ** | Warning |
1 metric are OUT OF RANGE!
generate_tcl (Begins at: 1371 Ends at: 1442)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
G_gui (Begins at: 1445 Ends at: 1467)
CalledNBR:    |       8 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
G_tcltk (Begins at: 1470 Ends at: 1485)
LOC:          |      16 |       |      OK |
metrics are OK
show_options (Begins at: 1487 Ends at: 1516)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
show (Begins at: 1518 Ends at: 1531)
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
set_flag (Begins at: 1533 Ends at: 1560)
LOC:          |      28 |       |      OK |
metrics are OK
contains (Begins at: 1565 Ends at: 1574)
LOC:          |      10 |       |      OK |
metrics are OK
set_option (Begins at: 1576 Ends at: 1636)
CalledNBR:    |      13 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
check_opts (Begins at: 1638 Ends at: 1675)
LOC:          |      38 |       |      OK |
metrics are OK
check_an_opt (Begins at: 1677 Ends at: 1719)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
check_int (Begins at: 1721 Ends at: 1787)
Complexity:   |      13 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
check_double (Begins at: 1789 Ends at: 1829)
LOC:          |      41 |       |      OK |
metrics are OK
check_string (Begins at: 1831 Ends at: 1858)
Complexity:   |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
check_required (Begins at: 1860 Ends at: 1883)
LOC:          |      24 |       |      OK |
metrics are OK
split_opts (Begins at: 1885 Ends at: 1948)
LOC:          |      64 |       |      OK |
metrics are OK
check_multiple_opts (Begins at: 1950 Ends at: 1988)
CalledNBR:    |       5 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
check_overwrite (Begins at: 1991 Ends at: 2047)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
interactive (Begins at: 2049 Ends at: 2077)
LOC:          |      29 |       |      OK |
metrics are OK
interactive_flag (Begins at: 2079 Ends at: 2087)
LOC:          |       9 |       |      OK |
metrics are OK
interactive_option (Begins at: 2089 Ends at: 2179)
Complexity:   |      23 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |      91 |       |      OK |
metrics are OK
split_gisprompt (Begins at: 2181 Ends at: 2211)
LOC:          |      31 |       |      OK |
metrics are OK
gis_prompt (Begins at: 2213 Ends at: 2258)
CalledNBR:    |      20 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
G_recreate_command (Begins at: 2260 Ends at: 2360)
CalledNBR:    |      25 |       |      OK |
LOC:          |     101 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  interactive_flag
In lib/gis/parser.c clones of  interactive_flag are:
	lib/gis/rm_colr.c  G_remove_colr
Threshold GRASS6 key metrics values at 2006-05-24 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
