[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca
Thu May 25 07:33:32 EDT 2006
Hello markus,
ANALYSIS
lib/gis/is.c functions
test_path_file (Begins at: 6 Ends at: 20)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 15 | | OK |
metrics are OK
G_is_gisbase (Begins at: 28 Ends at: 31)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
G_is_location (Begins at: 39 Ends at: 42)
LOC: | 4 | | OK |
metrics are OK
G_is_mapset (Begins at: 50 Ends at: 53)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-05-25 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 40 | 182 | 253 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
