[GRASS-QA] GRASS QA: paul | ./grass6/lib/display/tran_colr.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Nov 3 15:24:57 EST 2006
Hello paul,
ANALYSIS
lib/display/tran_colr.c functions
D_translate_color (Begins at: 25 Ends at: 52)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 28 | | OK |
metrics are OK
D_translate_or_add_color (Begins at: 54 Ends at: 105)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 52 | | OK |
metrics are OK
D_allocate_color (Begins at: 107 Ends at: 123)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 17 | | OK |
metrics are OK
D_parse_color (Begins at: 125 Ends at: 144)
Complexity: | 3 | | OK |
LOC: | 20 | | OK |
metrics are OK
D_raster_use_color (Begins at: 146 Ends at: 158)
CalledNBR: | 2 | | OK |
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-11-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
