[GRASS-QA] GRASS QA: paul | ./grass6/lib/gis/get_ellipse.c |no clones | 0 monsters | 0 warnings
Fri Nov 3 15:24:57 EST 2006
Hello paul,
ANALYSIS
lib/gis/get_ellipse.c functions
G_get_ellipsoid_parameters (Begins at: 63 Ends at: 178)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |     116 |     * |         |
metrics are OK
G_get_ellipsoid_by_name (Begins at: 181 Ends at: 254)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
G_ellipsoid_name (Begins at: 257 Ends at: 287)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
G_get_spheroid_by_name (Begins at: 290 Ends at: 320)
ParamNBR:     |       4 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
G_ellipsoid_description (Begins at: 323 Ends at: 327)
LOC:          |       5 |       |      OK |
metrics are OK
get_a_e2_f (Begins at: 330 Ends at: 369)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       5 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
ellipsoid_table_file (Begins at: 371 Ends at: 375)
LOC:          |       5 |       |      OK |
metrics are OK
compare_table_names (Begins at: 378 Ends at: 382)
LOC:          |       5 |       |      OK |
metrics are OK
read_ellipsoid_table (Begins at: 385 Ends at: 460)
CalledNBR:    |      25 |       |      OK |
LOC:          |      76 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-03 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
