[GRASS-QA] GRASS QA: paul | ./grass6/lib/gis/get_projname.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Nov 3 15:24:58 EST 2006
Hello paul,
ANALYSIS
lib/gis/get_projname.c functions
G_ask_proj_name (Begins at: 23 Ends at: 90)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 38 | * | |
LOC: | 68 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-11-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
