[GRASS-QA] GRASS QA: brad | ./grass6/lib/cdhc/shapiro2.c |1 clones
( kse.c kuiprsve.c shapiro2.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Nov 3 23:17:03 EST 2006
Hello brad,
ANALYSIS
lib/cdhc/shapiro2.c functions
shapiro_francia (Begins at: 10 Ends at: 45)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 36 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
shapiro_francia
In lib/cdhc/shapiro2.c clones of shapiro_francia are:
lib/cdhc/weisberg.c weisberg_bingham
Threshold GRASS6 key metrics values at 2006-11-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
