[GRASS-QA] GRASS QA: paul | ./grass6/lib/proj/ellipse.c |no clones | 0 monsters | 0 warnings
Sun Nov 5 06:36:57 EST 2006
Hello paul,
ANALYSIS
lib/proj/ellipse.c functions
GPJ_get_ellipsoid_params (Begins at: 39 Ends at: 51)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
GPJ__get_ellipsoid_params (Begins at: 54 Ends at: 136)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |      83 |       |      OK |
metrics are OK
GPJ_get_ellipsoid_by_name (Begins at: 138 Ends at: 158)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
get_a_e2_f (Begins at: 161 Ends at: 198)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       5 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
read_ellipsoid_table (Begins at: 200 Ends at: 278)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |      79 |       |      OK |
metrics are OK
GPJ_free_ellps (Begins at: 280 Ends at: 285)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
free_ellps_list (Begins at: 287 Ends at: 300)
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-05 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
