[GRASS-QA] GRASS QA: brad | ./grass6/lib/driver/Draw.c |no clones | 0 monsters | 0 warnings
Tue Nov 7 04:40:57 EST 2006
Hello brad,
ANALYSIS
lib/driver/Draw.c functions
DRV_draw_bitmap (Begins at: 5 Ends at: 9)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
DRV_draw_line (Begins at: 11 Ends at: 15)
LOC:          |       5 |       |      OK |
metrics are OK
DRV_draw_point (Begins at: 17 Ends at: 21)
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
