[GRASS-QA] GRASS QA: brad |
./grass6/lib/fonts/for_grass/splitfont.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Nov 7 04:40:57 EST 2006
Hello brad,
ANALYSIS
lib/fonts/for_grass/splitfont.c functions
main (Begins at: 8 Ends at: 121)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 34 | | OK |
LOC: | 114 | | OK |
metrics are OK
savechar (Begins at: 123 Ends at: 137)
Complexity: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 15 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-11-07 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
